1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97 venge motor swap to a stealth motor
Old Dec 1, 2007 | 03:32 PM
avengerking3's Avatar
avengerking3
Default 97 venge motor swap to a stealth motor
hey i have a 97 avenger that i really want to redue. i want to do a motor swap to a dodge stealth twin turbo but i have no clue exactly what i need. so if anyone can help it would be awsome. thanks
Old Dec 1, 2007 | 05:38 PM
PappiDread6's Avatar
PappiDread6
Default RE: 97 venge motor swap to a stealth motor
You can't with out a mess load of dough motors too big for our bays. Exspecially the TT motor yes I know the engine code is the same as our V6 motor.
Old Dec 1, 2007 | 05:44 PM
bad venge's Avatar
bad venge
Section Moderator
It is physically impossible has been attempted more times then I can count , no one has successfully done it the motor is just too big
not to mention the tranny wont fit ect ect ect Completelly rewiring and moving all sensors/computers ect ect ect
Old Dec 4, 2007 | 05:52 PM
avengerking3
ok that sux. so what would be the easyest thing to do i want a lot of power and i want to put what i can in there. so if u have any suggestions please let me know so i can buy the motor
Old Dec 4, 2007 | 06:31 PM
bad venge's Avatar
bad venge
Section Moderator
The 3.0 motor swap is the easiest direct bolt ...
You can also swap for a GSX motor/awd if you want
Old Dec 5, 2007 | 01:08 PM
avengerking3
what kind of 3.0 and what car should i get it from
Old Dec 5, 2007 | 06:17 PM
bad venge's Avatar
bad venge
Section Moderator
https://dodgeforum.com/m_559206/tm.htm
