1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Headers For the 2.5
Old Dec 31, 2007 | 02:39 PM
ayTurboSebring's Avatar
ayTurboSebring
Default Headers For the 2.5
ok well i found some pacesetters for my 2.5L
http://www.autopartswarehouse.com/sh...e/avenger.html
and everywhere that i found it..it says that it fits the 2.0L and the 2.5L.. why does it fit the 2.0 also..does that mean the 2.0's can fit on the 2.5L also? it dosent make sense..
Old Jan 1, 2008 | 12:32 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Headers For the 2.5
I've never seen those listed before....There was only one set ever built before byXIR and they have went away... Disturbing Motorsports sent a set of them out to be reproduced...
Old Jan 1, 2008 | 01:34 PM
bad venge's Avatar
bad venge
Section Moderator
I've called my buddy to have him check with his rep on those to see if they exist
Old Jan 4, 2008 | 04:55 AM
ayTurboSebring
ok thanks..do you know since it says that that one fits 2.0 and 2.5 that i can just buy the 2.0 ones?
Old Jan 4, 2008 | 12:15 PM
bad venge's Avatar
bad venge
Section Moderator
The 2.0 are 4cylinder headers Doubt they'd fit on a V6[:@]
Old Jan 7, 2008 | 02:38 PM
ayTurboSebring
how would i know for sure? u know cause it only makes sense that if the 2.5 one fits the 2.0 than than it should be visa versa..i dont know too much about cars but u think its just false info? or a typo or somthing..you know a lot more about cars than i do..
is it possible? before i buy them lol
Old Jan 7, 2008 | 07:28 PM
bad venge's Avatar
bad venge
Section Moderator
Do you NOT read .... the 2.0 is a 4Cylinder That means that all four exit into the header.... The 2.5 is the V6 that means that three exit out the front and three out the rear,
the headers are NOT interchangeable....
The company rep has NOT returned my buddies phone calls soI'm not sure if they exist for the 2.5 ...
Old Jan 7, 2008 | 10:10 PM
bad venge's Avatar
bad venge
Section Moderator
Rep called they have NO 2.5 application the part number is the same as the 2.0 and was a mistake in the catalog that the website copied
Old Jan 8, 2008 | 03:35 AM
ayTurboSebring
ok thanks..so with no headers for the 2.5 is there anything other than a intake..that i could buy that wuold give my exhaust a better sound?
or is there anywhere else you knwo of that u can still find 2.5 headers..i know they are hard to find
Old Jan 8, 2008 | 12:15 PM
bad venge's Avatar
bad venge
Section Moderator
headers were made in a limited run by XIR, they have been run out of buissiness after ripping off several other forums with header group buys... disturbing motorsports sent a set of the xir headers out to be remade , check there ...
