1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Car Jumping!!
Old Jan 28, 2008 | 04:12 PM
PappiDread6's Avatar
PappiDread6
Default Car Jumping!!
96 5speed I4
WhenI left off the clutch a lil and give it a lil gas I hear this pounding sound like im rinding on bear rims and they have flat spots and im trying to do a burnout.Umm you ever rev you car up and dropped it into gear and heara loud pound its like that be faster.The vibration of it felt throughout the car. I check the motor mount my front mount bolt fell out replaced itand I just changed my trans mount, changed the master cylinder cause it was leakin.. I can't get it to too it all the time I noticed it happen often in stop and go traffic where im constanly hit and lettin off the clutch, also when the ground is wet Ill get it. Now Im at a point where Im jerkin the carbecause im lettin off the clutch too fast or burn up the clutch, justso it won't happen again. I tried have them look at it at work 3 techs couldn't get her to act up. There prognosis is that I can't drive a standard. I'm thinkin its something with the crankshaft, I also thought my flywheel was warped cuz when I let off clutch after the noiseI would hear something else spinning. IDK
Old Jan 28, 2008 | 08:21 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Car Jumping!!
Sounds like a bad throwout bearing to me
Old Jan 29, 2008 | 09:22 AM
PappiDread6
Its messed up because I can't get to do it all the time, so some are saying its my stick driving ability. I know its not cause this is the only car that I had it happen to. I just to narrow it down to either the engine or trans.
