1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 avenger Door lock
Old Feb 16, 2008 | 12:16 PM
mrrccc's Avatar
mrrccc
Default 95 avenger Door lock
okay so heres the deal. i was changing the door handles on the car, and it was very cold outside. i got the handle on. but i never connected the rod for the handle. i closed the door on accident and now theres no way to get in through the passenger side. the inside handle doesn't work and the outside handle doesn't work. any ideas?
Old Feb 16, 2008 | 03:27 PM
sprman9's Avatar
sprman9
Default RE: 95 avenger Door lock
take a screw driver to it and pry it off.i broke both door handles at once and thats how i had to get back in...
Old Feb 16, 2008 | 07:04 PM
bad venge's Avatar
bad venge
Section Moderator
you should be able to get the inside door panel off , remove the screws and pull out ... worst case remove the seat to get you more room to do it ...
remove the panel and get in and pop the latch ...
Old Feb 17, 2008 | 08:34 PM
sparkie791's Avatar
sparkie791
remove the panel around the inside handle (one screw) use needle nose pliers to pull bottom rod toward the left. should open...
