1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 Avenger 2.5 overheating
Old Mar 6, 2008 | 01:58 PM
jaquinn@aol.com's Avatar
jaquinn@aol.com
Default 96 Avenger 2.5 overheating
Hello, My Son has a 96 Avenger 2.5 and it was low on anti-freeze. It does not run hot at idle (no matter how long and the fan cycles on and off). If you drive it at all, the temp will continue to climb. Is there anyway to identify if it is a clogged radiator, the water pump or a head gasket? There is no anti-freeze in the oil, I do not smell any anti-freeze at the exhaust pipe. The water pump was replaced with the timing belt at 70K and the car now has 135K. This is very frustrating... Thanks
Old Mar 6, 2008 | 02:52 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 96 Avenger 2.5 overheating
I'd replace the radiator cap and thermostat ...I'm guessing that either the cap is weak or the thermostat is stuck ...
Old Mar 6, 2008 | 03:05 PM
yanickee's Avatar
yanickee
I'd say check the cap and thermostat like bad venge recommends. If this won't help, flush the system. Hope there is no air in the system!
Old Mar 6, 2008 | 07:43 PM
jaquinn@aol.com
***Update*** installed the new thermostat and cap and have the same result. I did notice that the heat is not hot either (since my son never mentioned this) and also the top hose is hot but the lower hose is ice cold... I am thinking the radiator is clogged up? This car does sit a lot since he is in college and only uses it while he is at home. Any help greatly appreciated!
