1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
no door handles
Old Mar 8, 2008 | 11:47 PM
ahsmom02's Avatar
ahsmom02
Default no door handles
How do you get into the car without door handles?
Old Mar 9, 2008 | 03:09 AM
darkestxxnight's Avatar
darkestxxnight
Default RE: no door handles
you fix them?
climb through your trunk... or smash the window out... or pull the door handle insidewith a clothes hanger...
Old Mar 9, 2008 | 03:22 AM
sprman9's Avatar
sprman9
that happened to me a couple of times this winter... i took a screwdriver and ripped off the doorhandle, since it needs replaced anyways. the key to my trunk doesnt work either, so that is what i came up with
Old Mar 9, 2008 | 09:54 AM
bad venge's Avatar
bad venge
Section Moderator
or are you talking shaved door handles ??? meaning the handles are removed ???
Old Mar 9, 2008 | 01:41 PM
98venge's Avatar
98venge
u may be able to pry the top of the window open a lilttle and shove a coat hanger or somthin to get the handle on the in side
Old Mar 10, 2008 | 06:24 AM
PappiDread6's Avatar
PappiDread6
there are two what im guessing are aluminm lines the upper one is the lock and the lower one is the for the door handle. They both slide left and right while inside the car. Tie something to the lower line and let it hang outside where your door handle would be or stuff it inside somewhere you can get to it.
Old Aug 3, 2008 | 06:03 PM
Rachel08's Avatar
Rachel08
I have no door handles I cracked my window alittle and tied a shoe string to the handle on the inside and let the rest of the string hang out the window lol
