1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
front wheel bearing hub assembly
Old Mar 21, 2008 | 04:59 PM
freedyp25's Avatar
freedyp25
Default front wheel bearing hub assembly
I need to replace my front wheel hub bearing assembly. The 4 bolts that hold it in from behind are nit accessible due to interference fromthe round shield for the drive axel. Not sure on how to remove this as I do not see bolts. I really do not want to break the clamp and take the rubeer boot off just to see if how its on if there is a better way. Does anyone know the best way to replace the hub assembly?
Old Mar 21, 2008 | 05:16 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: front wheel bearing hub assembly
just replaced my passenger front bearing last weekend. unbolting the upper ball joint,taking the brake caliper off the caliper braket,removing the bolt from the bottom of the shock/strut,unbolting the stabalizer from the strut/shock assembly,taking the 12mm bolt out that holds the brake line to the steering nuckle assembly,and the 2 10mm bolts for the abs wire(if your car has abs) then unhooking the outer tie rod. you can push straight down and out on the nuckle assembly far enough to remove the axle from the bearing. and have it rest to the side out of the way. loosen the 4 bearing bolts untill they stick out about 1/8 inch then smack the bolt heads with a hammer to knock the bearing loose. then just loosen the bolts some more and smack them some more,loosen...smack..untill it is free. or if you dont care to hurt the probably already junk bearing. take the bolts completely out,and smack that bitch with a small sledge hammer. just have to make sure you hold on to the steering nuckle assembly on the top so when you smack the bearing,the lower ball joints dont get damaged.
Old Mar 21, 2008 | 05:42 PM
freedyp25's Avatar
freedyp25
thnaks, I'll give that a try
Old Mar 23, 2008 | 06:26 PM
BigBoy121988's Avatar
BigBoy121988
i need to know if i can use the rearwheel hub bearing assembly off a 97 for my 96 wheel hub bearing assembly and what parts cant i use off of the 97....i need to know because i can by a 97 parts car for 300 dollars
Old Mar 24, 2008 | 12:13 PM
bad venge's Avatar
bad venge
Section Moderator
cheat call the parts store and ask for a part# for the 96 then the 97 if they are the same you are golden
Old Mar 25, 2008 | 11:37 AM
BigBoy121988
its to late for the 97....he scraped it
bv..... you live in ohio do you know of anywhere i can get an avenger parts car
i called most of the clevland area junk yards and either they dont have one or they wont sell it
Old Mar 25, 2008 | 12:00 PM
bad venge's Avatar
bad venge
Section Moderator
I search car-parts.com they have a junkyard database ...
