1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
dual battery
Old Apr 9, 2008 | 11:20 PM
Beasty's Avatar
Beasty
Default dual battery
maybe you guys can help me with this cuz all my researching took me to truck engines but i want to hook up a dual battery system for my audio system i know i gotta get an isolator and an upgraded alternator but can you guys what kind of alternator would be recommended for my engine on a dual battery system? thanks alot
Old Apr 10, 2008 | 12:24 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: dual battery
It depends on YOUR system how much current is needed, to recomend an alternator need the wattage rating of your amp/amps to figure current draw ...then I can give you alternator size, wire size, ect
Old Apr 12, 2008 | 05:29 AM
Beasty's Avatar
Beasty
a 200 watt amp, 800 watt amp, 750 watt power converter to run a laptop and a touch screen monitor and um i think thatst all i was gonna run system wise
Old Apr 12, 2008 | 09:47 PM
bad venge's Avatar
bad venge
Section Moderator
I'd upgrade the big three with larger wire and I'd upgrade to an Optima or Stinger in the front your current is well within the 110 amp alternators range ,
Old Apr 13, 2008 | 04:19 AM
Beasty's Avatar
Beasty
so pretty much a replacement alternator from advanced autos would do? i think those are 110 amp alternators arent they?
Old Apr 13, 2008 | 10:41 AM
bad venge's Avatar
bad venge
Section Moderator
You already HAVE a 110 alternator ....
Old Apr 14, 2008 | 09:12 PM
Beasty's Avatar
Beasty
oh ok my bad i was reading wrong..... thanks man
