1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
oil pressure switch?
Old Apr 26, 2008 | 03:50 PM
blackvenger's Avatar
blackvenger
Default oil pressure switch?
my 95 avenger has been leaking oil for some time now... i just got the time o jack it up and see where it is coming from. it looked at first to be coming from the half shaft seal, but then i looked above it and it was dripping out of the oil pressure switch connector... i unplugged the connector and saw that this was the sounrce of the leak... does this seem right or is there something more to this? i would think i would only need a new oil pressure switch, but im not sure...
Old Apr 26, 2008 | 04:07 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: oil pressure switch?
It could even just be leaking from the thread ,, Some teflon tape might take care of the leak
