1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1996 dodge avenger 2.0L DOHC
Old May 8, 2008 | 03:41 PM
Norm's Avatar
Norm
Default 1996 dodge avenger 2.0L DOHC
Im going to race this car on dirt/Tar oval track, in a pretty much stock class.... need some help with power and set up, any ideas????
Old May 8, 2008 | 04:10 PM
disturbingavenger's Avatar
disturbingavenger
Junior Member
Default RE: 1996 dodge avenger 2.0L DOHC
That depends a lot on what your budget is and what the rules are for the class you plan to run.
I can tell you a lot of ways to make the most power out of that engine but i am sure most of them would be outside the "stock" class
Old May 10, 2008 | 06:15 PM
jamesmviele's Avatar
jamesmviele
wiring schematic for ecu. got nething?
Old May 10, 2008 | 10:48 PM
disturbingavenger
Junior Member
wiring scematic for the car's wiring harness?? yeah i have them, what do you need to know
Or are you speaking of a diagram of the internal workings of the ECU, if so good luck with that because nobody really has that info
