1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Car too low
Old May 12, 2008 | 03:53 PM
UncleBoehl's Avatar
UncleBoehl
Default Car too low
I recently purchased a 99 Avenger that has been customised by the previous owner, the problem is that helowered ittoo much for the roads around hereand the front bumper has been broke and the driver's side side skirt has been ripped off halfway. I was wondering what I need to raise the car couple inches so when I get a new body kit for it the same thing don't happen to it. Thanks for any help.
Old May 12, 2008 | 03:57 PM
ViperGTS's Avatar
ViperGTS
Default RE: Car too low
You might be able to get away with only needing struts and springs. That's assuming he didn't mess with the camber arms. But if the camber arms are adjustable you would only need struts/springs.
Old May 12, 2008 | 10:09 PM
bad venge's Avatar
bad venge
Section Moderator
Do you know what type/brand of springs. or coilovers were used ??? you might be able to adjust if it is coilovers... if it's springs you might get another brand with less drop , or return to stock springs
