1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
i have a question about these cars?
Old May 16, 2008 | 11:07 AM
91satanslegend's Avatar
91satanslegend
Default i have a question about these cars?
hi, i have a 1991 acura legend, that i am most likely swapping for a 1998 dodge avenger, it has less than 100,000 miles on it, my mom used to have one of these, and i loved it. when do the transmissions start to give out on these cars? and what problems usually occur after the 100,000 mile mark? thanks alot
Old May 16, 2008 | 06:22 PM
PappiDread6's Avatar
PappiDread6
Default RE: i have a question about these cars?
You best bet is to take to your local shop and have them look over you vehicle to see what it needs. THE FIRST thing I would do is check if the recall has been preformed on your lower control are. I could write up a list of things to be changed on our cars at certain mileage intervals.
Old May 16, 2008 | 09:33 PM
bad venge's Avatar
bad venge
Section Moderator
trannies are unpredictable I've seen 300k on the factory , and under 30k keep fluid changed and install an extra tranny cooler
Old May 26, 2008 | 08:51 PM
bcrunk's Avatar
bcrunk
my factory tranny is still running fine at 180k. everything on it runs awsome minus some weirdness with the front tires
Old May 27, 2008 | 08:05 AM
scatpackmopar's Avatar
scatpackmopar
I have a 98 Avenger with 242K miles on it. I had to replace my 5 speed tranny at 159K miles becauseI failed to notice a leak that ran the tranny dry so it cooked itself [there was an engine leak at the same time and I didn't know that our cars run 30 weight oil in the tranny so I thought all that oil was engine oil, after I got the engine leak fixed the tranny was out of oil so I never noticed it leaking] I changed the timing belt when I repaired the oil leak and I have not had any prolems with the car since then. It does use a litle bit of oil but nothing that wouldn't be expected from a car with 242K miles on it. I do have a right front bearing making noise that needs to get replaced [I hit a curb] I get 27MPG city and usually get 34MPG highway [I got 36.6MPG on a trip throught the Blue Ridge Mountains a few years ago]
Old May 28, 2008 | 12:03 AM
bcrunk's Avatar
bcrunk
yeah I get about 27-28mpg city and 34-35mpg inter. so thats good to know that this car runs pretty good with higher miles
