1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Backup light switch...??
Old May 25, 2008 | 01:01 PM
Tiddy427's Avatar
Tiddy427
Default Backup light switch...??
I've checked all my fuses and relays, and I'm down to the backuplight switch as the prob, but I can't seem to locate the damn thing...
any ideas on where it might be!? Thanks guys!
Old May 25, 2008 | 01:44 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Backup light switch...??
You don't say manual or automatic ???
Old May 30, 2008 | 10:29 PM
slinky1202's Avatar
slinky1202
If it is a 95 v6 venge you would need to replace the relay. You can buy a fog light relay that will make the backup lights work. This is only for an auto and not a man. You will see on the firewall three relays by the washer fluid container and one of them can be bad. I used a simple fog light relay for $5.00 and it fixed my backup light switch problem. You should be able to pull the switch out and press it in to make the lights go on. If it doesn't I would try this fix before buying a new switch. Well good luck.
Old May 31, 2008 | 06:40 AM
bad venge's Avatar
bad venge
Section Moderator
The three relays on the firewall are NOT the reverse lights (see sticky above)... The switch on an automatic is on the front of the transmission
Old May 31, 2008 | 09:57 AM
Tiddy427's Avatar
Tiddy427
It's a manual...
