1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
AC Problems
Old Jun 1, 2008 | 06:59 PM
cbook's Avatar
cbook
Default AC Problems
Hello, everybody I have a 99 ES 2.5 my question is when i put my AC on it just blow out cool but not cold air and whenI turn my radio down I hear a noise like it stuggling I wonder what is the problem???
Old Jun 1, 2008 | 08:38 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: AC Problems
Low on coolant freon R134
Old Jun 1, 2008 | 11:04 PM
cbook's Avatar
cbook
Ok thanks bad venge and I got one more question (it make be dumb question but here it goes)Do I just buy the freon kit and will it stop filling once it full or do I need to know the exact amount freonthat I need, because I heard two different answers.
Old Jun 2, 2008 | 08:58 AM
tom01973's Avatar
tom01973
you need to know about how much you need.if you over fill the system it won't cool as well and you can damage the compressor.i would buy the kit and 1 can of r134a and add it slowly until you feel a change in the temp. coming out of the vents.you can use a thermometer to tell the temp.50-55 degrees is what you should shoot for.
Old Jun 3, 2008 | 09:56 AM
cbook's Avatar
cbook
ok thanks alotI tried it today and I think it got a little cooler sodo a buy a half of can r134 and slowly put it in just like you said before cause the first bottle is used up???
