1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Problem Starting
Old Jan 29, 2004 | 04:39 AM
Dsnuz's Avatar
Dsnuz
Default Problem Starting
<img border="0" src=smileys/smiley19.gif border="0">
Has anyone experienced or does anyone know why on a 1997 Dodge Avenger ES, why the key won't turn? I live in Nebraska, we are having really cold weather right now, when I went to drive the other day, I put the key in the ignition and I simply cannot turn the key. I have moved the steering whell, hit the brakes, moved the gearshift back and forth, but I cannot turn the key.
I finally got the car to start, after checking in the middle of the day and the key turned without a problem, but then later in the day, the same problem occured again. Is this just due to the extreme temperatures of-20 windchills and air temps of 0 and below. Any info would be great.
Old Jan 30, 2004 | 02:52 AM
RDE's Avatar
RDE
I HAVE A DODGE AVENGER 1996 AND HAVE THE SAME PROBLEM. I LIVE IN THE UPPER PENINSULA OF MICHIGAN, WHERE IT IS COLD ALL THE TIME!! I AM TRYING TO FIND A BLOCK HEATER FOR IT AT THE MOMENT. I FOUND THAT WARMING THE KEY UNDER A LIGHTER AND THEN TRYING IT WORKS. IT SOUNDS STUPID BUT IT HAS WORKED WHEN I HAVE TRIED IT.
Old Jan 30, 2004 | 04:34 AM
71RoadRunner's Avatar
71RoadRunner
You might want to try a can of white lithium grease. It has a straw like WD40, just tap the nozzle because you don't want too much in there, I wouldn't want you to possibly get it on the ignition switches contacts and keep it from working.<edited><editID>71ROADRUNNER</editID><editDate>38016.0661111111</editDate></edited>
Old May 31, 2004 | 05:30 PM
Dano Sport's Avatar
Dano Sport
Default RE: Problem Starting
I had that problem one time last summer. It was the middle of summer after some drag racing, i sat there for a good 20 minutes with nothing. Then for no reason it turned. So i dont know if its a cold thing cause it was like 80 degrees out when it wouldnt turn. So i dont know. It could have to do with the steering wheel lock and it just jams up.
