1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Help on 2.5 timing belt
Old Jun 6, 2008 | 10:59 AM
varmintjcl's Avatar
varmintjcl
Default Help on 2.5 timing belt
I changed the timing belt & water pump on my 1996 2.5 & now I have a knock, I hope its not the valves kissing the pistons. I checked & double checked the timing before I reassembled, but did I miss something?
Is it possible for all three timing marks to be lined up & still not be at TDC on this engine?
And on the tensioner pulley it calls for a special tool to postion the pulley correctly as it is oblonged & can be moved around before tightning it.
I tightened it when I had it in position so I could pull the allen holding the tensioner pin easily back & forth before removing it.
Is it still possible that the timing was incorrect?
Old Jun 6, 2008 | 12:07 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Help on 2.5 timing belt
Was this a maintenance replacement ???
Or was the timing belt broken ???
Old Jun 6, 2008 | 12:26 PM
varmintjcl's Avatar
varmintjcl
this was a maintenence replacement. we pulled the engine out as we also had an oil leak at the rear seal &
it had overheated so we decided to change the water pump since we couldn't figure out anything but a low water condition.
I just pulled the cam timing covers & rotated the crank to TDC & the timing marks are all dead on.
I'm baffled. Now it's got me wondering if I did something wrong on the flywheel.
Old Jun 6, 2008 | 12:28 PM
varmintjcl's Avatar
varmintjcl
we did a compression check before we pulled the engine & got 145 at all cylinders & no bleed off.
we also did a cooling system pressure test & it held at 25psi for 20-30 min.
Old Jun 6, 2008 | 12:57 PM
varmintjcl's Avatar
varmintjcl
Ok more updates, I've got my fingers crossed..I found the bolt holding the crank position sensor loose allowing the sensor to touch the flywheel. Am in process of reassembling the timingcovers & stuff & hoping to restart with any more noises.
Old Jun 6, 2008 | 02:05 PM
varmintjcl's Avatar
varmintjcl
That took care of it, starts now & runs without all the noise, although it still seems to have a roughness especially at idle. I'm so tired of screwing with this car I think its time to take it to a shop for some diagnostics.
Old Jun 6, 2008 | 09:21 PM
bad venge's Avatar
bad venge
Section Moderator
Glad to here it wasn't a bad fix
