1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
interior lights not working
Old Jun 14, 2008 | 02:23 PM
mrjim1965's Avatar
mrjim1965
Default interior lights not working
I was thinking it was the bulbs however when I tried the switch inside the car, the lights didn't turn on as well, you know the switch I'm talking about, the one that makes the dashboard dim. What is the fuse for the Room Lamp for??? Can this be the fuse I'm looking for???
Old Jun 14, 2008 | 03:30 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: interior lights not working
That dimmer switch doesn't turn the interior lamps on for me either. It never has and I'm the original owner. I have a sunroof too. If you can turn on the lamps with the switch on the mirror, then your bulbs are fine.
Old Jun 15, 2008 | 08:45 AM
bad venge's Avatar
bad venge
Section Moderator
Didn't I answer this before for you ... If the lights turn on the mirror, the Door switches are likely bad and can buy new for $6/$10 at the parts store
Old Jun 16, 2008 | 05:05 PM
mrjim1965's Avatar
mrjim1965
Same as my other post, put problem in the subject.... Sorry
