1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
R&R front bumper
Old Jun 14, 2008 | 11:53 PM
Laynlow's Avatar
Laynlow
Default R&R front bumper
Hi ALL
I have a 98 Avenger and need to re-place fromt bumper< does anyone know how this is done?
Old Jun 15, 2008 | 08:37 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: R&R front bumper
You'll need to remove the following,
2-10mm bolts in the front fenderwell in front of the wheel well , It's easiest to remove the black inner fenderwell in the front to reach them remove both sides (drivers/passenger side) these are likely to be stubborn and break easily
there are four Plastic screw type rivits in the top of the grill opening remove all four
Next remove the headlights 3-10mm bolts per side , the headlichts then need unplugged and worked out since the sides are loosened it's pretty easy...
Two more plastic rivets under the headlights
then the five 10mm bolts across the top center front
