1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
throttle body bore
Old Jun 15, 2008 | 06:45 PM
mark1267's Avatar
mark1267
Default throttle body bore
I have read what you guys say about the boring of the throttle body to 60mm how much performance does it add? what does it doe for fuel economy?
Old Jun 15, 2008 | 07:36 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: throttle body bore
Well, what happens is the motor takes in more air, the o2 sensor reads leaner than normal and compensates by adding more fuel. This in turn lowers your overall MPG. Don't think about it as just adding more air because the computer will automatically compensate for it all the way to it's highest map setting or threshold.
Old Jun 16, 2008 | 12:04 AM
mark1267's Avatar
mark1267
Any idea on the performance gains?
Old Jun 16, 2008 | 12:09 PM
bad venge's Avatar
bad venge
Section Moderator
My fuel economy stayed virtually the same .. As long as you are not running it wide open all the time ...
I bored the TB and port matched the upper /lower plenum and extrudehoned the plenum at the same time added around 12HP from the previous dyno reading
