1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
EGR
Old Jun 16, 2008 | 02:00 AM
fil327's Avatar
fil327
Default EGR
Hello, I just gave my little brothers1998 Avenger sport a tune up, plugs gas filter wires ect. and now the damn check engine light came on.AsI drive it the light will go off but comes back onagain, got the code checked andit indicates EGR valve has a problem. Is it really the egr valve or did i do something wrong or forget to do somethingwhen I did the tune up? Thanks
Old Jun 16, 2008 | 12:06 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: EGR
I4 or V6 ???
Old Jun 16, 2008 | 11:44 PM
fil327's Avatar
fil327
Default RE: EGR
V6 1998 Avenger Sport
Old Jun 17, 2008 | 12:07 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: EGR
Since you had the plenum off to do the rear plugs I'd double check the connections ect on the middle rear of the plenum (EGR) valve ...
Old Jun 18, 2008 | 12:13 AM
fil327's Avatar
fil327
Default RE: EGR
Will do. Because I did break the vacum hose and had to replace it but I will check everything else again. Let me ask you one thing. Should I replace the Plenum seal with a new one or some sort of sealant, because I didnt. The one that was on there looks ok but I dont know if I compromised the seal when I took off the Plenum. Thanks again.
Old Jun 18, 2008 | 10:35 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: EGR
I can normally get three removals from one gasket
