1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Power windows stopped working. PLEASE HELP!!
Old Jun 17, 2008 | 11:31 AM
MoparLuv's Avatar
MoparLuv
Default Power windows stopped working. PLEASE HELP!!
Hi, my passenger side door handle broke off and we replaced it. Well, right after that the passenger side window and door looks on both side stopped working. We took off the panel and found that the door locks weren't hooked up, fixed that and hoped that was the problem with the window as well. Well, now my door locks work, but the passenger side window still won't work, from neither switch. We checked to make sure there was current going through, and there is. We checked to make sure nothing came loose, don't see anything. The window was working just fine with no signs of any problems at all til we fixed the door handle.
We are leaving Friday for vacation and this is my only ride! Really need that window to work! Please if anyone has had the same thing happen or knows how to fix this let me know asap!!!
Also, we are changing the oil, any recommendations on what type of oil? It has 101k miles on it.
Thanks in advance!
Old Jun 17, 2008 | 12:05 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Power windows stopped working. PLEASE HELP!!
Since you were in the door to replace the handle Double check the connector feeding the switches and the connectors to the motor ...
Also check the child proof window disabler on the drivers door panel...
If thats all good check for voltage at the motor , Voltage and no movement= Bad motor
you did check the fuse ???
Old Jun 17, 2008 | 12:15 PM
MoparLuv's Avatar
MoparLuv
ORIGINAL: bad venge
Yes we checked the fuse, checked the voltage, there is power there. We can even hear a noise when we check it but the noise is coming from under the dash. Some type of humming sound? We checked the switches and connectors... still can't find the problem.
Old Jun 17, 2008 | 02:43 PM
mark1267's Avatar
mark1267
Check the power right at the window motor plug, if you have current there then you need motor. You may need to push the window button to get power flowing into the plug.
When you pick it up at the parts store and buy the curved screwdrivers for easy access or you will be kicking yourself later.
