1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
right front wheel bearing hub
Old Jun 18, 2008 | 11:57 PM
Goliath442's Avatar
Goliath442
Default right front wheel bearing hub
i was just wondering how to replace the front passenger wheel hub on a '98 dodge avenger es? the 4 bolts are extremely hard to get at an i was wondering if there is a special tool to get these bolts out or if you need to do something to get the axle covering out of the way?[:@] . i have tried thin wrenches and sockets but neither have worked. hope someone can help thanks
Old Jun 19, 2008 | 01:46 AM
khooper's Avatar
khooper
Default RE: right front wheel bearing hub
try the J 42129 Wheel Hub Remover (this is a fairly generic tool you can rent from some parts stores - you may or may not need this tool - you won't know for sure until you remove the hub nut )
________________________
Check out: Autopartswarehouse.com
Old Jun 19, 2008 | 12:04 PM
bad venge's Avatar
bad venge
Section Moderator
We changed one out at a car show with just standard hand tools ... remove the brake/caliber /brackets/ dust sheild
Old Jun 19, 2008 | 06:20 PM
mark1267's Avatar
mark1267
Advance has a front end service kit and a hub bearing removal tool that you can get, you pay for it, use it, then return it and get ALL your money back, or you can keep it if you like.
