1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
removing headlights?
Old Jun 19, 2008 | 06:12 PM
rollingdodge's Avatar
rollingdodge
Default removing headlights?
I was thinking about replacing my headlights but was wondering if you have to take the front fenders off to do? I can't get them out? or do you know of a site that shows you how? thanks
Old Jun 19, 2008 | 06:48 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: removing headlights?
I have a PDF for headlight removal. PM me with an email address and I'll email it to you a bit later and when I am able to get on my PC for the file ... or Pappi may have it handy.
Sorry that it's on a PDF and not online anymore. It used to be, but has since been removed. Luckily I saved it.
Old Jun 19, 2008 | 09:07 PM
bad venge's Avatar
bad venge
Section Moderator
There are two ways to remove them ...
proper is to remove the two screws that hold the front fascia to the fender , then remove the three bolts holding them in with the fascia loose they can be worked out ....The problem is that the bolts holding the fascia on while likely break as rusteats them
Scary way but works is to remove the three fender bolts closest to the headlight and pull up carefully on the fender and use that space to work the lights out ... it helps to have two people to do it this way
Old Jun 20, 2008 | 06:14 AM
PappiDread6's Avatar
PappiDread6
Yeah I still have the PDF for the Headlight removal. I can also e-mail to you. I can also hook you up with a link just incase you want to remove your headligh lense and paint them.
Hey silver how you know I still had it?
Old Jun 20, 2008 | 03:53 PM
mark1267's Avatar
mark1267
I am getting ready to do this also ... I didn't realize it would be a such a difficult task as you guys make it out to be. But, since I have not looked at it yet I would like to know if I can you get me a copy of the directions also? Thanks in advance
Old Jun 20, 2008 | 11:17 PM
Thundercleese's Avatar
Thundercleese
Would appreciate a copy of this doc as well if possible. Spenta while trying to remove last weekend and I was going to give it another shot tomorrow.
Old Jun 21, 2008 | 07:14 AM
PappiDread6
PM the e-mails of the people who want the Headlight PDF and Ill be more than happy to e-mail it to you.
Redneckracer e-mail has been sent
Old Jun 21, 2008 | 07:51 AM
PappiDread6
Mark - e-mail has been sent as well
