1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Correct Idle Speed. EGR Valve.
Old Jul 12, 2008 | 08:13 PM
Poolboy's Avatar
Poolboy
Default Correct Idle Speed. EGR Valve.
IDLE SPEED:
Does anyone know what the correct idle speed for a 1997 dodge avenger 2.5 should be? I tried checking the VECI label in the engine compartment, but couldn't find the label. Also, how do you measure the cable deflection between the throttle lever and the cable casing? Apparently it should be .04 to .08 inch but I'm not too sure how to get that measurement.
Thanks for the help!
EGR VALVE:
How can one inspect the EGR valve to determine if it is working properly or requires replacement?
Thanks again.
