1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 avenger wont start.. again
Old Jul 19, 2008 | 03:25 AM
Kris16's Avatar
Kris16
Default 95 avenger wont start.. again
a couple of days ago my car decided it did not want to start anymore. It had been running fine all day then later on i went to start it and it wouldn't go. The car has power but as soon as the key is turned the starter wont engage, there is just a clicking noise somewhere from within the dash near the radio. The car has a brand new battery. The relays all appear to be working as the fuel pump comes on and the starter works when power is applied to it. The worst part is the only code that pops up from the CEL is 55.
Old Jul 20, 2008 | 09:04 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 95 avenger wont start.. again
I don't show a code 55 are you sure on that # , it skips that number put it's in the electrical area ...
Have you tried jumping the car ??? It has a new battery but it could be low on juice or bad cell ...
Old Jul 22, 2008 | 11:38 AM
fupkid1's Avatar
fupkid1
Junior Member
Clean your battery turminals.Check the connections at the starter
Old Jul 22, 2008 | 06:35 PM
Kris16's Avatar
Kris16
I tried to boost the car but that did not work. The fuel pump came on but when i turned the key nothing again.
Old Jul 24, 2008 | 07:08 PM
Kris16's Avatar
Kris16
I located the clicking noise. It is from a relay behind the Radio that is in a rubber holder. It clicks as soon as the key is turned to "start". What does this relay control?
Old Jul 25, 2008 | 01:18 PM
Kris16's Avatar
Kris16
does anyone know what this relay does? I dont want to go pick up a new one if it is working properly and something is causing it to shut down.
