1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
afterswap ac issues
Old Aug 24, 2008 | 10:49 AM
otis84's Avatar
otis84
Exclamation afterswap ac issues
Long story short, I swapped out the 2.0L DOHC out of my 1995 Avenger and put back in the 2.5L SOHC. Everything but the AC works properly. I think that the issue is the Automatic Compressor ECM (TN277100-0590 by Denso) which I think is the original unit. I cannot remember if I actually replaced it when I did all the work a couple of years ago. Does anyone know if this ECM is compatible with the scroll compressor that comes on the 2.5??
When I push the button to AC Max, it works for about 4-5 seconds and then the light goes to blinking and the air quits being cold. I know the compressor itself is good and I can keep the AC going by playing with the button, but that gets tiring when I am trying to drive for a couple of hours at a time. Any ideas, comments, or thoughts will be greatly appreciated...
