1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Shift solenoid??? Tranny???
Old Aug 25, 2008 | 04:37 PM
th1eternaldragon's Avatar
th1eternaldragon
Junior Member
Default Shift solenoid??? Tranny???
i have a 1997 dodge avenger es v6 it has 187,000 miles auto trans. i have a engine light on so i took a code reader and it said shift solenoid, tcm, and tcm malfunction. i have been told that it is possibly be something inside the tranny. is there anyone that if it is something inside or if it is just a solenoid, or both the soleniod and the tcm? thank you
Old Aug 26, 2008 | 06:58 AM
bad venge's Avatar
bad venge
Section Moderator
Is the tranny working ??? Or is it in limp mode (stuck in second gear)??? Is the Speedo working ???
Old Aug 26, 2008 | 05:18 PM
th1eternaldragon
Junior Member
it is in limp mode the tranny works and i made sure the speedo worked yesterday. someone told me to check it.
Old Aug 26, 2008 | 05:33 PM
bad venge's Avatar
bad venge
Section Moderator
I try to start with the cheapest part ... The input speed sensor ... It's around $15/30 depending on the area ...
Sticky at the top has the location for you ...
Old Aug 28, 2008 | 11:15 AM
th1eternaldragon
Junior Member
i cleared the codes and it drove fine everything working speedo and all no delays or anything and then it goes to shift then it went right into limp mode. it sould be just the solenoid right?
Old Aug 28, 2008 | 12:13 PM
bad venge's Avatar
bad venge
Section Moderator
Again it could be the Input speed sensor ,the TCM or the solenoid pack ....Any of those three items can put it into limp mode as well as an internal tranny trouble ...
