1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Transmission problem please help!
Old Oct 4, 2008 | 03:57 PM
avengerproject's Avatar
avengerproject
Default Transmission problem please help!
hello people Im the new kid on the block and I have a problem with my 95 avenger. You see recently my transmission leaked all the tranny oil I thought it was the main seal beheind the torque converter, so I replased it put everything back and after everything. I started the car and there goes all the fluid again I need a help does anybody know what could be wrong with it?
Old Oct 4, 2008 | 08:01 PM
bad venge's Avatar
bad venge
Section Moderator
did you check the cooling lines that run to the radiator ??? I've seen a leak in them run down the tranny
Old Oct 5, 2008 | 03:23 PM
avengerproject
yes I checked the cooling hoses. I took out the flywheel cover and I know that its leaking from behind the torque converter but like I said I replaced that seal.
