1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Head Gasket
Old Jul 6, 2011 | 05:27 PM
bad venge's Avatar
bad venge
Section Moderator
2 YEARS is a long time to trust a tstat ... I'd replace that first and test the cap for proper release too early can cause the same trouble... I'd rather replace $20 in parts that take minutes before tearing down the motor
Old Jul 7, 2011 | 11:49 AM
Parmie's Avatar
Parmie
Default I'll give that a try first...
Thanks for the feed back, we'll give it a try and see what happens. I'll let you know!
Jeff
Old Jul 14, 2011 | 01:17 PM
Parmie's Avatar
Parmie
Default Thermostat AND gaskets
Thermostat was repalced and cured the over heating, however, the system has pressure in it indicating exhaust is the coolant. The oil and the coolant are NOT mixing so, it looks as if the gaskets will be done in the future. Gonna have to stay on top of the temp and coolant level....
