1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Brake warning light
Old Nov 19, 2008 | 03:49 PM
usemy3rdarm's Avatar
usemy3rdarm
Default Brake warning light
Trying to get my e-check done but failed due to the red warning brake light on the dash, can anyone shed some light on what causes this to be on? i checked the e-brake its not on, im lost on what to do about this. please help thanks
Old Nov 19, 2008 | 04:04 PM
bad venge's Avatar
bad venge
Section Moderator
It can be either the E brake switch , or can be low fluid level in the resevoir , it's a dual indicator for either
Old Nov 19, 2008 | 04:19 PM
usemy3rdarm
wheres the e-brake switch located?
Old Nov 20, 2008 | 10:36 AM
bad venge's Avatar
bad venge
Section Moderator
in the center console , by the brake lever ... pull the tray out from under the armrest to get a look at it ...
Old Nov 20, 2008 | 09:53 PM
khooper's Avatar
khooper
its way down hidden on the hinged end of the E-Brake lever.. its better to check it asap..if you need to buy new one there are many store who are having their clearance sale now. you might get a great discount there.
Old Dec 1, 2008 | 01:52 PM
Mavman's Avatar
Mavman
Default I had the same problem.....
Even though my fluid was alright in the brake fluid resiv for some reason the computer thought that it was low so I topped it off with a little more brake fluid to put it a little below the max line and viola.....my brake light isn't on all the time now.
