1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
problems
Old Jan 8, 2009 | 02:20 AM
95dangervenger's Avatar
95dangervenger
Default problems
okay ive got a 95 avenger 2.0 dohc. i chunked a timing belt a while back so i rebuilt the motor oil pan up. i put motor in the car and now it wont start. it has fuel, fire, and will crank til kingdom come but wont start. i have replaced ecu, crank position sensor, and cam position sensor. im at a loss if u have ne ideas let me know.
Old Jan 8, 2009 | 08:40 AM
bad venge's Avatar
bad venge
Section Moderator
Are you POSITIVE the timing is right ??? Have you run a compression test ???
Old Jan 8, 2009 | 05:31 PM
95dangervenger
we got it started. took the spark plugs out to run a compression test and smelt no fuel on them so we changed the fuel rail with an extra i had. once it primed that fuel rail it started right up. clogged injectors i guess. and im pretty sure the timing is off one tooth but it did start up thats was a relief. but thanks for the input bad venge.
of by the way these guys on here with starter problems, u might tell them to check their starter gorund.
Old Jan 8, 2009 | 06:08 PM
bad venge's Avatar
bad venge
Section Moderator
I've not seen many with starter troubles .... more that it cranks , won't start
