1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
SRS dummy light
Old Jan 24, 2009 | 10:56 PM
mark1267's Avatar
mark1267
Default SRS dummy light
Does anyone know what causes the SRS Airbag dummy light to come on and stay on?
Thanks in advance
Old Jan 25, 2009 | 09:56 AM
bad venge's Avatar
bad venge
Section Moderator
It can be a number of things ... A dealer can scan and tell you the exact cause ...
The most common cause is the clockspring failure in the steering wheel assembly compressing and not making good contact on the air bag itself ...
Old Jan 29, 2009 | 07:12 PM
daytonapartout's Avatar
daytonapartout
is it in an automatic?
reason i ask is i had the same issue in mine, but i lost overdrive also. after months of digging it came out to be a short in a wire harness that is in the trunk.. (so says dodge)
