1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Dash speakers......
Old Feb 16, 2009 | 09:55 AM
Mavman's Avatar
Mavman
Default Dash speakers......
Okay so my set of dash speakers (the tweeters) blew and I got another set out of the junkyard. I did a battery test to see if they were in working condition and they were. Now these tweeters are the upgraded ones that have the cap on them for the bass blocker. I was just wondering if there was something that I have to adjust to get them to work because when I plug them in there is no sound coming through them. I don't want to remove the cap because that will make them more likely to blow. Greatly appreciate you help and awaiting it also.
Old Feb 16, 2009 | 10:51 AM
bad venge's Avatar
bad venge
Section Moderator
no should be plug and play ... even the stock tweets have the bass blocking cap ...
I upgraded to the bose home tweeters ...
Old Feb 16, 2009 | 10:07 PM
Mavman's Avatar
Mavman
Default well......
my originals didnt have the bass blocking cap but these do. any idea why they wouldnt work???
Old Feb 16, 2009 | 10:10 PM
bad venge's Avatar
bad venge
Section Moderator
Nope , I'm assuming the old ones worked before correct ???
Did you turn the fader cause they were blown ???
Old Feb 17, 2009 | 11:07 AM
Mavman's Avatar
Mavman
nope.... my fader is the little **** on the stock infinity head unit so....yea......
Old Feb 17, 2009 | 11:32 AM
bad venge's Avatar
bad venge
Section Moderator
nope they didn't work before ???
The fader is turned to allow front speakers ???
Old Feb 22, 2009 | 10:36 AM
johnnybegood_5's Avatar
johnnybegood_5
I don't mean to highjack this thread but how do you test speakers at a junkyard? I can think of a bunch of times when i found nice speakers sitting around ,but didn't think it was worth looking at them.
Old Feb 22, 2009 | 12:36 PM
bad venge's Avatar
bad venge
Section Moderator
There's really not a great way to test at the yard ... I take a drill driver and use the battery to attach to the speaker you should hear an audible click/pop when you connect (9volt battery works in a pinch)... It checks for voice coil and spider continuity ... Inspect the speaker surround for cracking ect
Old Feb 23, 2009 | 03:41 PM
Mavman's Avatar
Mavman
Default Yes that is what I did.....
my fader and balance are on a ****. I still have the stock infinity head unit and its set so that it will play through all speakers so I just don't get why they wont work. Oh yea....Know anyplace to get a good tranny for under 1500. My front seal or pump is out.
