1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Doorlock problem
Old Feb 23, 2009 | 02:33 AM
luckyvenge's Avatar
luckyvenge
Default Doorlock problem
ok fellas i got a problem with my doorlocks for some reason they seem keep unlocking constantly on their own the problem with this is that it sies it all day and its killing my battery, do you guys think its the doorlock relay? or do you guys have any idea what it could be? thanks in advance
Old Feb 23, 2009 | 08:48 AM
bad venge's Avatar
bad venge
Section Moderator
Do you have the factory Alarm System ???
Old Feb 23, 2009 | 11:55 AM
luckyvenge's Avatar
luckyvenge
badvenge I do not have any alarm system.
Old Feb 23, 2009 | 12:09 PM
bad venge's Avatar
bad venge
Section Moderator
usually the door lock/unlock is a switch in the door getting flakey that is for the factory alarm system ... If you say you don't have it I'm thinking you might and not know it...
Try this , roll down the window, and lock the doors with the keyless , in the center of the dash there should be a security light lit (but could be burnt out) reach in and unlock the door and open it ...If the horn starts you have a factory alarm ... you'll have to use the key in the doorlock to reset it
Old Feb 23, 2009 | 12:33 PM
luckyvenge's Avatar
luckyvenge
ok maybe i should of told you this first, when i got this car the only thing i got was a single key, so I sume that it does not have keyless entry. so I cant try what you told me. what do you think
Old Feb 23, 2009 | 02:19 PM
bad venge's Avatar
bad venge
Section Moderator
here are a few ways to go about it :
1)get the keyless fob from ebay/dealer and program it ...then try , plus you get keyless
2) remove the drivers door panel and look for the switch , and disconnect it see if it helps
3) try the relay ...
Old Feb 23, 2009 | 04:23 PM
luckyvenge's Avatar
luckyvenge
ok thanks badvenge I'm going to try it.
