1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
eclipse manual transmission?
Old Mar 2, 2009 | 01:06 PM
BackToBlack's Avatar
BackToBlack
Default eclipse manual transmission?
i am looking for a manual transmission for my 95 Avenger. i found one out of a Eclipse GS and was wondering if they will swap out ok? i thought they might being it is the same 420A motor in both of the cars, but the transmission numbers are different. i have a F5MC1 and the eclipse has a F5M31 in it. what is the difference? i am at a loss and i need some help.
thanks
Old Mar 2, 2009 | 05:32 PM
virginatheavenger's Avatar
virginatheavenger
okay they wont eclipses never used the 420 they used 4g63 motors 420a was a dodge thing not an eclipse u would have to swap motors too
Old Mar 2, 2009 | 05:46 PM
Ethan98ES's Avatar
Ethan98ES
Actually the 420A motor was used in the 2 generation eagle talons and Mitsubishi eclipses. The 4g63 motors were used in the 1 generation of those cars.
Old Mar 2, 2009 | 09:59 PM
BackToBlack
yes it would be out of a second gen eclipse. and i know they had the 420A engines in them because i have worked on many of them. i just don't know if the transmissions will work together. i would think they would but i have no clue to be honest...
Old Mar 3, 2009 | 12:20 AM
virginatheavenger
the 2nd gens have them too how do u think the 2nd gens had turbos if you reall want this manual tranny get it out of a neon they are all the same
Old Mar 3, 2009 | 02:41 AM
luckyvenge's Avatar
luckyvenge
hello virginia, so any tranny from a neon with a 420A engine would work, how about the links, clutch pedal, shifter, can you use the same ones from the neon or do have to use the eclipse ones
Old Mar 3, 2009 | 10:56 AM
Ethan98ES's Avatar
Ethan98ES
Hey BacktoBlack yes the eclipse tranny will fit in your car i am 100% sure of this.
Old Mar 3, 2009 | 03:33 PM
virginatheavenger
im not big on the 420a motor had alot of problems with them so it may work it all depends if the shift linkage fits
Old Mar 15, 2009 | 03:12 AM
Tiddy427's Avatar
Tiddy427
Just to set the record straight...420A motors were used in 2nd Gen NON-TURBO Eclipse and Talon models (and of course neons and avengers!). The 4G63 engine is the TURBO motors in both the Eclipse and Talon. The linkage from the eclipse should be exactly the same. The difference in numbers is probably because they come from two different car companies. All the parts I buy for my 95 Avenger, with the 420A, I buy parts listed as eclipse parts and sometimes even Galant. Finding a local performance shop would be the best option if your still unsure, those guys do a lot of mix-n-match stuff!
As for the tranny out of the GS...it should fit, no problem!
