1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Brake light switch????
Old Mar 15, 2009 | 09:30 PM
Hippie138's Avatar
Hippie138
Default Brake light switch????
Hello.... I've been searching and searching for some type of manual to tell me how to change my brake light switch. I've tried a bunch of different things and nothing seems to work so I decided I better just ask someone if they could tell me the easiest way to change it. I've got a 99. Thanks for the help
Old Mar 15, 2009 | 10:45 PM
bad venge's Avatar
bad venge
Section Moderator
The brake light switch is pretty easy lay in the floor and look up follow the brake pedal up and you will see the the switch , pushing the brakes allows the switch to turn on ,
I forget of the top of my hear if it's two screws or bolts holding it to the bracket
