1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
sunvisor lights
Old Mar 23, 2009 | 01:51 PM
crazyvenge's Avatar
crazyvenge
Unhappy sunvisor lights
Hi! im new here in this forum i have a 95 dodg avenger es and well i have no idea why my sunvisor lights dont work i check them and they are connected and well i try to check all the fuses but nothing and im not even sure if i checked all the fuses, someone tell me why are they not working? thanking for the help.
Old Mar 23, 2009 | 08:58 PM
bad venge's Avatar
bad venge
Section Moderator
You'll need to get a VOLTMETER or test light and check if there is voltage coming in or not .. if there is voltage coming in the bulbs could be bad or the switch failed
No voltage = bad wire or blown fuse you missed
