1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Need help with Code P0301
Old May 11, 2009 | 04:19 PM
luckyvenge's Avatar
luckyvenge
Default Need help with Code P0301
Hey guys and gals My avenger got the SEL On, I checked the codes and P0301 came up I also have the same code pending. It says its misfiring but I does not sound like it is, I recently put in a pulgs and cables, and even a MSD ignition coil, cleared the codes but today they appeared again any ideas on what could be going on with this venge?
by the way I have the 420A engine (2.0L)
Old May 11, 2009 | 09:07 PM
bad venge's Avatar
bad venge
Section Moderator
Recheck all the newly installed parts , just cause they are new doesn't guarentee they were installed correctly
