1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Cruise Control
Old May 21, 2009 | 07:56 PM
JVenger's Avatar
JVenger
Default Cruise Control
I have a 2000 Dodge Avenger and am having trouble with the cruise control. it doesn't seem to hold the Mph when i set it. the cruise control light comes on but it doesn't stay at the set miles it just goes down. i dont know what it could be. help, thanks
Old May 21, 2009 | 09:59 PM
Killa200's Avatar
Killa200
check your hard plastic vacuum line going to the cruise control box for cracks and breaks. That line leaking usually causes the issue you are describing.
Old May 22, 2009 | 02:23 AM
bad venge's Avatar
bad venge
Section Moderator
if the lines not cracked the actuator black box on passenger side strut tower may be bad as well
Old May 23, 2009 | 07:05 PM
JVenger's Avatar
JVenger
did a visual inspection but all seems fin but the actuator box seems to have been opened previously so it maybe with that. Is there a fuse that maybe needed to be replaced? thanks again
Old May 23, 2009 | 09:31 PM
bad venge's Avatar
bad venge
Section Moderator
If the light comes on the fuse is OK
