1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1998 2.5 Avenger ES
Old May 29, 2009 | 12:50 AM
mlstorz's Avatar
mlstorz
Exclamation 1998 2.5 Avenger ES
So here's the problem.
I bought the car with a known problem of bad fuel injectors- I fixed them, and everything was running smoothly for about 3 days.
Then, I started to get problems from the computer saying that the 3rd cylinder was misfiring. I replaced the distributor, to hopefully fix the problem.
But, now its idling lower, and feels like it could die at any time. I'm gonna try the Spark Plugs and wires next. any other ideas? ALL help would be greatly appreciated!!!!!
~Mat
Old May 29, 2009 | 09:50 AM
JLA74's Avatar
JLA74
Change your plug wires and since you have to remove all the junk on the top of the motor anyway to get to the back three make sure to check for vacuum leaks.
Old May 29, 2009 | 06:07 PM
bad venge's Avatar
bad venge
Section Moderator
Clean the EGR valve out when you have the upper manifold off
Old Feb 15, 2010 | 04:14 AM
mlstorz's Avatar
mlstorz
I ended up figuring out the problem.... it was a bad fuel filter.
