1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Trunk and license plate lghts not working
Old Jun 4, 2009 | 11:20 PM
fil327's Avatar
fil327
Default Trunk and license plate lghts not working
1999 Dodge Avenegr Es. Anybody have any idea why my inside trunk and license plate lights dont work. I changed all the bulbs but still no luck. thanks
Old Jun 5, 2009 | 11:45 PM
bad venge's Avatar
bad venge
Section Moderator
well did you check for voltage ??? if there's no voltage could be a fuse/wire issue ...
for the trunk lighht tere is a contact on the trunk latch a single wire on it unplug it and ground it if the trunk light works the switch is bad
The plate lghts can go out if there is too much rust on the ground of them as well
Old Jun 6, 2009 | 12:36 AM
daragez's Avatar
daragez
that's right!...check them all!....
Old Jun 8, 2009 | 12:36 AM
fil327's Avatar
fil327
Default Will do
Thanks for the advice will let you know the results.
