1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Need help with o2 sensor location...p0134
Old Jun 14, 2009 | 08:59 AM
muleman's Avatar
muleman
Default Need help with o2 sensor location...p0134
got a code p0134.. bank 1 sensor 1 02 sensor....................is bank one on the number 1 firing side of the engine the rear of the engine and so the first sensor down stream... this is the one i changed and still getting the cel.........any help... thanks.
Old Jun 15, 2009 | 11:48 AM
PappiDread6's Avatar
PappiDread6
on mitchell it a says Left Bank Upstream HO2S Stays at center, but the Avengers O2sensors vary on year.
I think the 95 Avengers on have only 1 upstream Heated Oxygen Sensor.
96 and up 2.0L Have 2, one just below the exhaust manifold, and the other is just after the resonator before the muffler
96 and up 2.5L v6 engines have 4. One on each bank, one where both banks meets and one downstream
Old Jun 18, 2009 | 12:31 AM
muleman's Avatar
muleman
yea thanks... i got it it was a pain to get out.. went through the bottom and got it instead of removing the upper intake... still throwing a p0300 multiple misfire code now...
