1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
A604 Trans Valve Body
Old Jun 16, 2009 | 06:28 PM
candacebadie's Avatar
candacebadie
Default A604 Trans Valve Body
My car's still not shifting into O/D and I was told that I needed a transmission valve body and I was wondering if the valve bodies on all the A604 transmissions (regardless of engine size) were the same?
Old Jun 16, 2009 | 09:30 PM
bad venge's Avatar
bad venge
Section Moderator
Did you check for 12 volts on the red wire goint to the OD switch ???
The I4 and V6 valve bodies are interchangeable
Old Jun 16, 2009 | 11:05 PM
candacebadie
I did check for the 12volts and my reverse lights and found no problems there. Are the valve bodies for the cirrus and the sebring the same as well?
Old Jun 16, 2009 | 11:19 PM
bad venge's Avatar
bad venge
Section Moderator
sebring coupe YES cirrus stratus unsure , check part numbers
Old Jun 17, 2009 | 11:03 PM
candacebadie
Just wondering which of these two valve bodies were for a 96 v6, because I've honestly never seen a trans valve body myself?
Attached Thumbnails A604 Trans Valve Body-valve-body-1.jpg   A604 Trans Valve Body-valve-body-2.jpg
Old Jun 17, 2009 | 11:25 PM
bad venge's Avatar
bad venge
Section Moderator
I doubt there is any way to tell by looking ...
Old Jun 19, 2009 | 03:50 AM
candacebadie
Default Worst case scenario
I pretty much figured that, just thought I'd let you guys take a stab at it, guess it's time to invest in another trans then, guess halos will just have to wait
