1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
lock/unlock door 1997 es 2.5
Old Jun 23, 2009 | 11:12 PM
muleman's Avatar
muleman
Default lock/unlock door 1997 es 2.5
anyway to get the horn to chirp when arm/disarm or lock/unlock with the key fob..
Old Jun 24, 2009 | 06:05 PM
bad venge's Avatar
bad venge
Section Moderator
You can run a relay in the lock circuit + into the coil and to ground then run a + source to the contact and a line from the N/O contact out to the horn wire on the horn relay
