1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
98 Avenger P0304
Old Aug 8, 2009 | 09:48 PM
nightrider340's Avatar
nightrider340
Default 98 Avenger P0304
OK banging my head agaqin... onething gets fixed another pops up.... I know its #4 cylinder misfire.... here is what I have done... cleaned TB, IAC, EGR, replaced plug and wire, swapped #4 & #6 fuel injectors... no change... didn't have a distributer cap... but I used an extention and stuck it up the wire and its got spark... anything anyone can think of??? and hoping I am right that the #4 is middle cylinder towards the front of the car.... thanks Rick
Old Aug 10, 2009 | 11:53 AM
Killa200's Avatar
Killa200
i can tell you off hand that yes #4 is the middle towards the front of the car. Have you ran seafoam through the system?
Old Aug 10, 2009 | 02:16 PM
bad venge's Avatar
bad venge
Section Moderator
I'd say cap/rotor is next logical step .. just cause you see spark it might not be good spark ...
Old Aug 10, 2009 | 03:44 PM
nightrider340
and Bad Venge wins... I just got back from PA...took a distributer cap and rotor along with a compression tester... cap was cracked and arcing... so just did the cap and rotor and told the stepson not to touch... hahahaha
