1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Locking up in reverse only?
Old Aug 26, 2009 | 09:56 PM
Shiano's Avatar
Shiano
Default Locking up in reverse only?
Ok, so i've been trying to give my new mechanic [and that depends on how this is all resolved..] some time to dive into my issue and he doesn't believe my issue is in the cv joint since it's only locking up when i go in reverse.
Anyone know what would make an NV-T350 [A578] transmission lock up only in reverse?
It has had the proper fluid for the past 3 years and i've changed it twice by my own choice/boredom. Last time was 8 months ago.
97 Avenger ES 2.0L
Old Sep 11, 2009 | 01:41 AM
virginatheavenger's Avatar
virginatheavenger
umm well you do know it has a differental on the side of the transmission u may have knocked the pin loose at one point and its causin that to lock up or u have took out some splines on the cv shaft which u could pull it out and look
Old Sep 11, 2009 | 08:25 AM
rzramon's Avatar
rzramon
Transmission locks while reversing cause just because the lock pin might got corrupted, so by servicing lock pin results as a solution to this problem.
Regards,
Razor
Old Sep 24, 2009 | 07:48 PM
Shiano's Avatar
Shiano
It was the Hub Assembly. lol
