1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97 v6 venge horn prob
Old Oct 22, 2009 | 09:56 PM
Mavman's Avatar
Mavman
Default 97 v6 venge horn prob
K so I cleaned the contacts and still the only time the horn wants to work is when after the battery is disconnected and even then it is only for a couple of honks and it sounds like it not getting enough voltage.
Any ideas???
Old Oct 23, 2009 | 06:46 PM
bad venge's Avatar
bad venge
Section Moderator
Check the horn relay does it click when depressed ???
Old Oct 24, 2009 | 07:02 AM
Mavman's Avatar
Mavman
Is the relay on the firewall or somewhere else
Old Oct 24, 2009 | 04:15 PM
bad venge's Avatar
bad venge
Section Moderator
I forget if it's in the fuse panel underhood or kick panel
