1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
'97 2.5L - oil in spark plug tubes?
Old Nov 10, 2009 | 01:24 PM
tobytigger's Avatar
tobytigger
Default '97 2.5L - oil in spark plug tubes?
When I removed the plugs there was oil in the tubes on my '97 avenger 2.5L. Is this normal?
Killa200's Avatar
Killa200
You need to replace the plug well seals.
Old Nov 10, 2009 | 04:40 PM
bad venge's Avatar
bad venge
Section Moderator
No it's not normal ... You need a valve cover gasket set (it comes with plug well seals )
You'll also need some high temp silicone RTV to do the install
Old Nov 11, 2009 | 10:24 PM
tobytigger's Avatar
tobytigger
Do I use silicone on both sides of the valve cover gasket? Should silicone be used on the new intake plenum gasket? The old gasket feels like a rubber material and the new gasket seems to be metal. Anyone know if this metal gasket requires a sealant?
I removed the intake plenum and found a lot of oil in the rear tubes and inside of the wire plug socket . This may be stupid question, but is it possible that all this oil on the wires and plugs caused the engine to stall?
Old Nov 12, 2009 | 08:44 AM
circumventor's Avatar
circumventor
yall dont use no sealers on this stuff. never use no sealers on intake plenum and forsure not on the valvecover except in the the corners where it goes from flat to arund the cam caps. and jsut a little dab. i seen allot of guys gob the snot out sealers and then it gets into to the moter plugs the pickup screen and smokes the barings.
Old Nov 15, 2009 | 07:39 PM
bad venge's Avatar
bad venge
Section Moderator
You HAVE to use silicone on the plug well seals to attach them to the valve cover , I apply a thin film and attach the plug seals and let them set up ... As well as the valve cover gasket ... this prevents moving when you flip up / over the valve cover
You can also use the gasket adhesives to hold it in as well
no sealant on the intake gasket ...
Oil can cause misses stalling as it grounds out the plugs
