1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Dont think my 97 avenger shifts into overdrive
Old Dec 6, 2009 | 08:56 PM
v6avenger09's Avatar
v6avenger09
Default Dont think my 97 avenger shifts into overdrive
My car is a 2.5 L automatic and i dont think overdrive works. My button on the shifter wont light up the light on the dash when un-pressed. also, when im going like 45, it wond down shift when i un-push the button. it could be the button itself or a fuse, because my e-brake light doesnt work, the fog lights dont work(under hood fuse good), and cruse doesnt work. The reason I think it doesnt go into overdrive is because it is at like 3500 rpms at like 55-60 mph. is this normal? also, i can tell the shift from 1st to 2nd, and 2nd to 3rd, but 3rd to 4th is a very small shift, like maybe 500-700 rpms? is my overdrive not working?
Old Dec 6, 2009 | 09:19 PM
bad venge's Avatar
bad venge
Section Moderator
Sounds like it ... Check the Reverse lights ... No reverse light check the fuse
