1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 2.5L and seafoam
Old Dec 29, 2009 | 07:07 PM
stishdr's Avatar
stishdr
Default 95 2.5L and seafoam
Hi, I have a rough idle i was told to run seafoam through the car. I need a little help with that..i know i need to put 1/3 of the can in the crank case, 1/3 into the gas tank, and 1/3 into the main vacuum line...i dont know where that is and need help locating it. I also was told to clean my IAC and EGR valve...need help locating them and how to clean them..if there was a diagram that would help...hopefully this will solve my idle issue, thank you.
Old Dec 29, 2009 | 07:27 PM
bad venge's Avatar
bad venge
Section Moderator
IAC= in throttle body ...
EGR= Rear middle of plenum ...
Vacumn line = attached to intake OR you can get a spray bottle and squirt it in directly
Old Dec 29, 2009 | 09:11 PM
stishdr's Avatar
stishdr
alright, i found the throttle body..not sure how im going to get to that..but where is the plenum exactly? i would like to clean/change the EGR valve..but i have no idea where that is..
Killa200's Avatar
Killa200
if you put seafoam in your crank case, do so right before you plan to change the oil, as the stuff really thins it out and cleans up the gunk, and you want to drain that stuff.
Old Dec 29, 2009 | 09:49 PM
bad venge's Avatar
bad venge
Section Moderator
plenum= what the tb is attached to the egr is dead center near the firewall
Old Jan 2, 2010 | 12:23 PM
varmintjcl's Avatar
varmintjcl
I had that rough idle on my daughters 96 2.5 and it turned out the rubber o-rings on the injectors were dryed out & leaking. also had a slight gas smell and this fixed both problems.
